Ram Air
- jake
Re: Ram Air
drill a small hole where you need them for the fuel line, choke/zip tie and throttle. You could get a rubber ring on each of the holes, or even some silicone?
I just drill mine tight and leave them as is, as the rubber/silicone thing just does you head in when you have to take airbox off.
Make sure with ams box that you neaten the inlets up. I had to take a fair bit off mine to match my carb rubbers. Then put a small amount of silicon under the airbox to seal to the head.
saltire88
- My Bike: ZXR 400
Re: Ram Air
Cheers Jake, I did notice the inlet holes where not a brilliant match. Time to get the dremmel out lol.
saltire88
- My Bike: ZXR 400
Re: Ram Air
This is not as easy as I though, some amount of messing about to get this fitted.
Re: Ram Air
The bottom half of the air box is a tight fit on the carb rubbers takes a bit of effort to get the thing seated properly
Needs to be a snug a fit as is possible to keep it air tight
Robbie
- My Bike: zxr400
Re: Ram Air
The ams box is a terrable fit.And is a lot more of a nightmare to put on or off.I wouldnt buy one.
Re: Ram Air
getting them off is a case of fortune favours the brave...................a good sharp tug.....................and hope it dont break....................
perhaps not
perhaps not
saltire88
- My Bike: ZXR 400
Re: Ram Air
Any idea what you do about the breather pipe from engine, have the rest done after hours of messing about. It is a bad fit but if it gives me a few more ponies then I will be happy. Hoping to get it up on the dyno today.
Re: Ram Air
you can run the breather into a bottle or drill yet another hole in the air box
Robbie
- My Bike: zxr400
saltire88
- My Bike: ZXR 400
Re: Ram Air
Have it fitted and will have it on dyno on friday all being well.
saltire88
- My Bike: ZXR 400
Re: Ram Air
OK back from Dyno and it is not good, It is worse than before I fitted kit. Was thinking of going down in the jets and using dyno jet needles. Has anyone any suggestions. Or has anyone ran a 400 with an open air box.
HELP HELP
HELP HELP
Re: Ram Air
what jets/needles are in there now ?
and how is it worse ?
rich ?
lean ?
lumpy ?
peaky ?
rich ?
lean ?
lumpy ?
peaky ?
saltire88
- My Bike: ZXR 400
Re: Ram Air
Should have got scan of dyno sheet. it is .5bhp more but basically no mid range and it is like a set of stairs from about 11,000rpm it is a bit like it is off a cylinder. I was told start with 120 jets and normal needles. I have now put 117.5s in and a set of Dyno jet needles set at 2 clicks. It even sounds better now and revs out smoother. Will have to wait until monday to get it back on dyno.
saltire88
- My Bike: ZXR 400
Re: Ram Air
Had bike back up on Dyno today. It is much better with 117.5 jets. extra 3.5 bhp. Not much but every little help lol. Top end is not bad but mid range still poor. Going to drop needles 1 click and see if that helps.
