Trouble getting into first
jonny
- My Bike: zxr400 L2
Just had trouble getting bike into first from neutral. Happened a few times. Just wondering if this is anything to worry about? And if anybody knows why it happens? cheers
kawaman
- My Bike: zxr750
Re: Trouble getting into first
It might be a problem with the clutch, if you didn't used the bike for a while the discs might be glued
Also check the shifter linkage...
Check your chain adjustment too.
Your clutch is draging or not lifting properly...............could be as simple as adjusting the cable to fix
jonny
Thanks for the help. Seems to have sorted itself out now.
