stuck bolt
zxr500man
stuck bolt
Post by zxr500man »
hello fellas,
i removed the swing arm today and shock,theres one bolt ,i got the nut off,the bolt spins freely,it will NOT come out,its the one that bolts the bracket on to the frame,the other end of the bracket is bolted to the shock,and then the dog bones onto the swing arm,it just wont come out,is it not suppose to come out? :smt017
Re: stuck bolt
It should come out....................I seem to remember that with my Mircon exhaust that particular bolt fouls on the exhaust and wont come out.
Ignoring that it most definately should come out....................might be siezed onto the bush...................hit it :excited with something
Davw
Re: stuck bolt
Post by Davw »
It is supposed to come out but it sounds like it is seized against the inside of the roller bearing in the shock linkage. Sounds like the application of some wd40 overnight and then gentle tapping - although TBH it doesnt need to be that gentle as it is likely that the shock linkage bearing is u/s
Davw
Re: stuck bolt
Post by Davw »
Bush - that was the word i was looking for - :ffs how could I forget that :pmsl
zxr500man
Re: stuck bolt
Post by zxr500man »
ok il try that.thanks
will#224
My Bike: L1 racer
Re: stuck bolt
Post by will#224 »
If you've got a decent G clamp you could put a socket over the head of the bolt and try pressing it out.
