**** Please read **** Over size Pistons / Rings
Posted: Fri Nov 27, 2009 8:49 am
by Mori Man
These are still available from an L4
part No. 13029-1210
However, there are no ring sets available from any model
But there are companies who do make piston rings so not all is lost !
Currently I was able to submit a request for 96 pistons (24 sets) with out a problem.
Re: 0.5mm Over size Pistons
Posted: Sat Nov 28, 2009 7:07 pm
by Robbie
What sort of price are the pistons and rings?
Posted: Thu Dec 03, 2009 7:53 am
by richardleonardadi
Check out E bay at the moment a guy is selling a new set.
zxr 400 highest prices easiest way to find them.
Posted: Wed Dec 09, 2009 7:13 am
by Mori Man
A few questions if some one can answer:
1) Were +1.0 available and if not are they desirable ?
2a) The "Kit" pistons - were these available in oversize?
2b) Who made them -ART ?
2c) Are they high comp' ?
if the company replies back that they can supply any of the above what number would be wanted ?
Personally I'm looking for high comp' standard as I have a brand new block in the cupboard but if there were at least a dozen sets of something needed I would press on and try get them made / ordered.
If some one has a set of high comp pistons - would you willing to "loan" so that they could be replicated ? I'm hoping to contact the maker directly so might not be necessary. I would put up my SP engine as collateral should anything happen to them or my set of FCR's.
Cheers,
MM!
Re: **** Please read **** Over size Pistons / Rings
Posted: Wed Dec 09, 2009 9:11 am
+0.5 was the only oversize available from Kawasaki........................
there may well be +1.0 out there but not from Kawasaki..................
Posted: Thu Dec 10, 2009 9:48 am
by mick41zxr
Mori,
Rob (Toecutter here on the forum has already done all the hard work) I have posted him a kit piston a few months ago & he has been developing a set of standard 3 ring pistons & oversize 2 ring race pistons. These are a cnc machined forges pistons designed by some of the best piston engineers around.
The ART pistons are a cast piston & as such will not be as stable at high speed & temp.
The ones Rob have developed use the crown of the kit piston (13.0:1 according to the kit manual
http://www.zxrworld.co.uk/Manuals/zxr400r.pdf) & are lighter than the standard piston. They have coated skirts & use a thinner cast iron compression ring. They will make a set of JE's look like truck pistons.
I have posted some pictures & details of the kit pistons here,
viewtopic.php?f=117&t=10108, They were only available in standard bore size.
He has been working on these for the last three months & done a dummy assemblies to ensure clearances are spot on.
Considering the cost of all development work & pedigree of the company manufacturing these pistons the price is very reasonable.
Don't forget they include pistons, rings, pins & clips.
Regards,
Michael
Posted: Tue Feb 08, 2011 12:57 pm
by Vic61
Does anyone know of any 0.5mm piston ring sets available?
Thanks in advance Vic.
Posted: Thu Feb 10, 2011 9:21 pm
by Max4music
Cant help you with new one, but I have 3 x 0.5mm overbore pistons with rings listed on ebay (item 110645806144)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 500wt_1156
