Recently rebuilt my master cylinder, and had loads of problems with the brakes before/since.
I have just looked at an OFFICIAL rebuild picture, and the kit in that picture has one less rubber sealy thing than what I had.
Myn has an extra rubber bit, which for some reason I think I put at the END of the spring, towards the outlet.
Is this why I now brake for cake?
Gonna re-strip tomorrow just to make sure, cos these fucking brakes will just not bleed up!
Master Cylinder - Parts Assembly?
- Wabby
- My Bike: ZXR400
Re: Master Cylinder - Parts Assembly?
Let me guess at something......................
The seal kit you fitted was a patern one..........from ................wemoto ? ? ? ?
- Wabby
- My Bike: ZXR400
Pattern one from eBay - But could well be the same as the wemoto one.cargo wrote:Let me guess at something......................
Could this extra bit be my issue?
Just need to find somewhere today that sells small internal circlip pliers to get it back apart!
- CaNsA
- My Bike: ZX6R F1
I done the same thing last week, was a ball ache
Kit from ebay,
1 spring
1 plastic plunger thingy to go on the spring
1 metal bit for the other side of the spring
1 circlip
1 dust seal
By mistake i put the plastic plunger thingy on the side of the "output" by the banjo and it end up pulling all the crap out of my lines, which was handy.
There was so much crap in there.
It was a ball ache getting the circlip out. I used a small screwdriver through the leaver fixing holes and another screwdriver to hold the piston down while a mate (Swiss Tony) got the clip out. Worked well, done the same for putting the clip back in.
Good luck matey
Kit from ebay,
1 spring
1 circlip
1 dust seal
Good luck matey
Here's some free advice..........................
You kind of need your brakes to be 100% right..............................YOUR BRAKES WILL SAVE YOUR LIFE ONe DAY.............................
WHY IN THE NAME OF ALL THAT HOLY WOULD YOU FIT CHEAP SH1T CRAP PATTERN PARTS TO YOUR BRAKES ?
Fact is you cannot justify it................there are no circumstances under whcih you can....................... none
Buy genuine Kawasaki parts for your brakes everytime
And get tose parts fitted by someone knows what they are doing................I read far too many postings on here about brakes that are weak and can't be bled properly
Not once ever have I had a problem bleeding ZXR brakes......................................... why is your fluid full of crap that crap should never never have been allowed to build up. Fresh fluid even twice a year could save your life crap in the fluid is very likly the seals wearing ...................... Crap in the fluid damages the seals...................
It's not rocket siecence guys...................
Rant over
Rant over
- CaNsA
- My Bike: ZX6R F1
addition,
Now that i have overhauled the master cylinder and got both lines going direct to it my brakes are sharper and more responsive.
that is all.
that is all.
- Wabby
- My Bike: ZXR400
Booked into the garage for them to bleed.
Hopefully all will be well!
- Wabby
- My Bike: ZXR400
Just had a call from the garage.
They have bled, still crap.
They have stripped calipers - Made sure all seals, pistons etc are ok, re-built and bled.
Still crap
Apparrantly one of the calipers sides is pushing the disc, hence the long movement in the lever.
The discs are good and straight they say - They gonna have a think and try again next week.
Anybody any ideas for me to flourish them with?
Still crap
i had this problem with mine for the MOT. What happened was i installed new bearings and according to the mechanic id not installed them properly and the wheel was off-set to the middle, the front wheel was solid becuase the pistons on the right of each caliper couldnt go back any further, although it span it it was hard work. The lever was also very spongy. He said that i needed to make sure the bearngs were driven in properly and to clean up the caliper, id then get a proper feel back at the lever. Sure enough a good whack of the bearings and a clean up of the caliper and id get the lever back and my front wheel span easily
- Wabby
- My Bike: ZXR400
Had my bearing changed by 'a mate' a few months ago, and now I come to think of it, this is when I started having braking issues (Ride out the next day I nearly ran on at a corner).RedexRobB wrote:i had this problem with mine for the MOT. What happened was i installed new bearings and according to the mechanic id not installed them properly and the wheel was off-set to the middle, the front wheel was solid becuase the pistons on the right of each caliper couldnt go back any further, although it span it it was hard work. The lever was also very spongy. He said that i needed to make sure the bearngs were driven in properly and to clean up the caliper, id then get a proper feel back at the lever. Sure enough a good whack of the bearings and a clean up of the caliper and id get the lever back and my front wheel span easily
Will ring the garage @ 9am to let them know.
If this sorts it - I owe you a beer Rob!
