Won't start
Posted: Sun Sep 13, 2009 10:55 pm
Bike won't start, totally died on me t'other day so here's the story:
Was running on fumes so refilled at Asda and set off, upto ~8k rpm and no power and cuts out, no noise. Battery is a bit shite so quickly died from trying to restart, got car battery and got it to fire but wouldn't rev above ~1.5k rpm no matter the throttle position. Pushed it home and did the following:
Check spark, firing strong on all 4
Stripped, cleaned and rebuilt carbs
Checked fuel pump operation, fine
Bypassed fuel pump and fed fuel directly to the carbs
Checked chain tension and tensioner (but not checked timing yet)
Swapped over the pulsar coil pickup
Still nothing, its sparking and getting fuel (I believe) but don't think it would lose enough compression on all 4 to not even fire, it ran sweet before it shut down. If comp was the issue would prob fire but just run shite for a while until it eventually died.
I don't think it is, but unless I've missed something obvious its timing as its the last thing I haven't checked but the bike ran sweet beforehand so surely couldn't be the cause?
Also someone mentioned something about corrosion in the ignition wires coming from the switch but they all looked fine.
Anything I've missed? Ideas?
