Re: Hello
Posted: Sun Sep 08, 2013 1:05 pm
my bike atm runs lumpy as hell as the carbs arent set up properly, ironic isnt it? me and banner have both done guides on getting your carbs right and both of us need to do them
anyway, im just going to go through everything from the start- tank clean, decent fuel, clean fuel filter, hoses ok, fuel pump working, all seals in good condition, carbs clean, correct jets, carbs set, balanced, valve clearances, airfilter clean, all air seals good, carbs mounted correctly, no air leaks... and done! do all those things, with the possibility of valves reseated/lapped and it will be loooooovely. and just to avoid any confusion with a certain member- if you are going to lap or reseat the valves you will have to do the valve clearances afterwards as they will have changed after lapping or reseating the valves. Ross
