Page 5 of 5
Re: ZXR 400 Project
Posted: Tue Jun 19, 2007 2:44 pm
by Mori Man
If the cam chain rattle clears after say 3K revs - you could remove the drift in the auto tensioner and file the nose off it allowing it to slide a few 'mm' more
If it is rattly all the way through, then for a quick fix - file the drift and also place a 2mm ball bearing at the head of the 1st tensioner spring. This will increase the pressure applied to the trailing blade and shut it up for a while!
Restriction. How about shimming your carb tops and stopping the throttle valves from fully opening? Once you get it about 3/4 opening get the bike dynoyed to show it has restricted power - sorted!!
Insurance. Difficult one !! Get third party only just now and build your discount up.
Tax. Think you can still declare the bike as not being used on a public roads but will be parked on a public thourghway so need it to be taxed. You have to apply directly to the Tax office.
Re: ZXR 400 Project
Posted: Tue Jun 19, 2007 2:47 pm
by Random
restriction : i can get some restriction plate easy but it's the certificate you need for the insurance dont you ?
Re: ZXR 400 Project
Posted: Tue Jun 19, 2007 2:51 pm
by Mori Man
Random wrote:restriction : i can get some restriction plate easy but it's the certificate you need for the insurance dont you ?
I thought a Dyno print out was sufficient - photocopy and send original to your insurers ??? Just make sure your name address and bike reg are on the print out.
Oh, also get the Dyno operator to cetify that the print out is true and correct to the date of the run.
Re: ZXR 400 Project
Posted: Tue Jun 19, 2007 6:21 pm
by Northern ANdy
mine haven't asked for any proof of restriction.
Oh and I've just thrown a whole mudguard out with those bits still on it
Bins gone now aswell
Re: ZXR 400 Project
Posted: Tue Jun 19, 2007 9:26 pm
by Random
no i dont really want to make the bike like that i want to be proud of what i've acheived is there a cam chain and tensioner kit ya can buy ?
Re: ZXR 400 Project
Posted: Tue Jun 19, 2007 9:27 pm
by Random
i think i'll ring an insurance company up tomorrow then again there hopeless and probably wont be abewl to help anyways still worth a try it could save me alot of money.
Re: ZXR 400 Project
Posted: Sat Jun 23, 2007 5:11 pm
by Random
Right then the bike passed the MOT very nicely no problems at all and i have reapaired the rattleing problem it was the cam chain tensioner, took it out give it a good clean up and pulled it up 2 clicks put it back in and job a good one bike sounds brilliant now just the sound of pure zxr 400 POWER !
all i want now to finish it off is a front mudguard fork protectors.
Re: ZXR 400 Project
Posted: Sat Jun 23, 2007 6:25 pm
by Mori Man
Nice One!
Happy for you mate, you've come such a long way with it you deserve a result
Re: ZXR 400 Project
Posted: Mon Jun 25, 2007 10:06 pm
by Random
Does anyone know if the H model front mudguard is the same as a L model ?
Re: ZXR 400 Project
Posted: Mon Jun 25, 2007 10:20 pm
Re: ZXR 400 Project
Posted: Mon Jun 25, 2007 10:34 pm
To further that post, im sure the fixing points are the same as the fork bottom seem to be the same on the L and H.
Re: ZXR 400 Project
Posted: Tue Jun 26, 2007 7:15 pm
by Random
The bike is now on ebay checked it out. Item number : 250136677388
Re: ZXR 400 Project
Posted: Wed Jun 27, 2007 8:46 am
why do all that work then sell it??
Re: ZXR 400 Project
Posted: Wed Jun 27, 2007 9:43 am
by rene
Re: ZXR 400 Project
Posted: Sun Apr 29, 2012 7:13 pm
by samchuck4
What tail fairing has it got on there?
