Page 4 of 4
Re: ZXR400 6pot Tokico upgrade.
Posted: Mon Sep 08, 2008 7:05 pm
by MillaMeter
Hi,
I'm well chuffed! Just bought some 6 pot calipers off ebay for 150 notes! GSXR1000 gold Tokicos! :smt003
Now... I could make some spacers for them as my old man has a metal lathe, or I could just tap em out to a bigger thread.
Has anyone tapped these calipers out yet? and is it easily done?
Regards
Rich
Posted: Tue Sep 09, 2008 9:39 am
by Gemini
also buy yourself a brembo 19x20 master cylinder, my eyeballs feel like they are being pulled out whenever i tap my lever now!
http://cgi.ebay.co.uk/BREMBO-RADIAL-BRA ... 286.c0.m14
Posted: Mon Oct 13, 2008 11:34 pm
by MillaMeter
Hi
I would buy a brembo M/C but the prices are really high! I was thinking of just getting a 7r M/C off egay or something. My old man bought me a 16mm alu rod to make the spacers up but he hasn't got round to shaping them yet, so I went out and bought myself a 1M alu tube for £2 from B&Q. The tube is 10mm with a inner 8mm diameter. Perfect for a quick fix. Slap a 16mm M8 washer on it with 4 M8x30 button head bolts and away you go!
I've ordered the bolts just gotta wait for them to arrive now, can't wait! :excited
If anyone is interested, I could post a quick step by step on this cheap mod when i've got my calipers all fixed up and working?
Regards
Rich
Posted: Sat Oct 25, 2008 7:04 pm
by MillaMeter
Hi,
I'm not 100% sure on this, but i'm pretty sure that SV1000 front calipers WILL also fit the ZXR400 H and L with only minor mods. Yet again, more spacers need to be made up, or you could do what I did and bought some 10mm alu tubing from B&Q with a 8mm inner diameter and cut 4 bits down to 19mm lengths. Then simply slap a 16mm M8 washer on top.
Regards
Rich
Posted: Sun Oct 26, 2008 10:43 pm
by Mr.Mash
Has anyone had any experence with these
http://cgi.ebay.co.uk/Front-Brake-Maste ... m153.l1262
the listing says
'THIS GOODS IS REMARKETING PRODUCTS, SO ITS MAY COME WITH MARKS AND SRCATCHED'
I know they have the brembo logo on but that dont really mean anything at the end of the day its a 19mm master cylender so its the right size just wondered if there worth the money?
ash
Posted: Sun Oct 26, 2008 11:27 pm
by Mori Man
This thread is for "Upgrades" :smt005
I like how it will work an extra 3 months with positive feedback :pmsl
So it's not Brembo, it's not billet and it will more than likely have the cheapest seals on the planet installed and you want to trust your life on it :smt018
How do you get a repair kit for it? If the Taiwanese alloy that I have encountered is anything to go by it will actually be a grade above bitter chocolate!
Definite - Buyer beware !!!
Fitting onto a Monkey, Ape or other 50cc bike - fine
Posted: Thu Oct 30, 2008 1:20 pm
by Mr.Mash
Well i know they wouldnt be the best or even nearly the best bit of kit you could get thats why i asked if anyone had experence with them,
how do you know the 13 or 14 year old seals in the standered m/c arnt going to fail on you or your going to have a blow out at 100+ there must be some kind of standerds they have to make them to?
Posted: Sat Nov 01, 2008 10:05 am
Someone asked about these on another forum yonks ago, they are simply cheap copies. I think the general concesus at the time was to steer clear of em.
Personally i wouldnt risk it, save the money and rebuild your standard master cylinder that has 14/15 year old seal in them. Its not expensive for a rebuild kit.
Posted: Tue Mar 17, 2009 3:56 pm
by WelshD1K
this is goign to sounds nuts but umm a pair fo calipers of a cagiva mito ?? ><
http://cgi.ebay.co.uk/cagiva-mito-evo-f ... 240%3A1318
4 pot brembo's look alot like the ones photographed
Posted: Tue Mar 17, 2009 4:24 pm
by WelshD1K
Posted: Tue Mar 17, 2009 11:19 pm
by Mori Man
WelshD1K wrote:this is goign to sounds nuts but umm a pair fo calipers of a cagiva mito ?? ><
They look like 40mm spacing (common brembo size) if not then 55mm - you'll need adapter plates for them.
Posted: Tue Mar 17, 2009 11:21 pm
by Mori Man
WelshD1K wrote:http://cgi.ebay.co.uk/Suzuki-SV1000-SV1 ... 240%3A1318
look like they may fit
Yip, 62mm is on the money :smt002
A modern equivalent of your originals.
Posted: Mon Jun 08, 2009 9:21 pm
by reds
will the sv1000 of any age fit a zxr 400 (H) - from what i understand so long as the fitting is 62mm they bolt straight on ? is this right ???
Posted: Fri Jun 12, 2009 8:12 pm
by Scott221
If its 62mm. It will fit. The problems lie with the bolt holes and spacing.
