Page 13 of 18
Re: I'm Down.
Posted: Wed Nov 05, 2008 12:55 pm
by Scott221
The fairings arent secured fully, only the top and bottom engine brackets are nipped up. What do you mean they are dropped through as far as they go?
I gave the guy the bike for the day. He builds and checks frames and he told me my forks were fine, frame is bent.
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:11 pm
Oh i see, so the whole lot was checked. Chances of another frame being bent the same way has gotta be pretty slim hasnt it.
My forks are dropped through as far as they will go. the fork legs are fatter mid way down for the clamps to clamp on to. If i go past the fat bit they wont clamp up tightly, so will only drop through so far before i can tighten them up. Hence, dropped as far as they will go :smt001
Re: I'm Down.
by Gemini
this bike's fightin u all the way aint it mate
will that fatter tyre still not give the impression that the wheel is closer to belly pan though?
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:15 pm
Gemini wrote:this bike's fightin u all the way aint it mate
Only if its like a 70mm circumfrence, like a 120/70/17.... what is the tyre size then scott?
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:16 pm
by Gemini
whatever it is, i know its 10mm larger
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:18 pm
by Scott221
120/70 tyre. Pirelli supercorsa pro. What should my next move be? Drop the forks through abit more? Buy a bottom yoke? I'll measure the spindle to mount now. Which mount did you use rob?
Re: I'm Down.
by Gemini
there u go then
also does the tyre touch the plastics when compressed?
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:20 pm
by Scott221
Gemini wrote:there u go then
Yeah, but I had the same tyre on before the new frame and its exactley the same.
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:25 pm
I used the swingarm pivot mate. Did you have a 120/60/17 when you had the accident?
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:27 pm
by Gemini
but its not to say that the bend in the original frame was causing the wheel to sit closer to fairing though
maybe im looking at it wrong, but if the tyre has a 10mm larger profile then surely it makes the circumference of the wheel/tyre 10mm larger :smt017
which to me means it would appear 10mm closer to fairing
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:31 pm
by Scott221
When I crashed I had a 120/70/17 on the bike AKA pirelli supercorsa pro which has stayed on the bike all the way through the rebuild. The frame was bent and the front wheel appear'd to be close to the fairing as you can see in the picture. I then stripped the bike replaced the frame and the wheel is exactley the same. Yeah, there is a 10 mil difference from a 120/60 - 120/70. I guess what I need is a picture of another bike with a 120/70 on the front.
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:33 pm
by Gemini
im sure someone one here with the smaller profile tyre will take a similar angle and distance pic of theirs for u scott
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:35 pm
by Scott221
Ok, just did a rough measurement with a tape rule from the front wheel to the swingarm pivot bolt and it appears to be around 85 cm. I'll do another one when another pair of hands arrive home.
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:36 pm
the tyre is 12mm difference, the 120/60 is 60% of the 120 the 120/70 is 70% of the 120 so 12mm difference.
Re: I'm Down.
Posted: Wed Nov 05, 2008 1:43 pm
by Gemini
well thats quite a difference aint it
just ditch the 120/70 scott
