Page 2 of 2
Re: neutral wire
Posted: Thu Sep 20, 2007 12:59 pm
by rene
got to admit i rarely leave the side stand switch on my bikes, ungly and cause problems, just easy to not have one!
Re: neutral wire
Posted: Thu Sep 20, 2007 3:47 pm
by carsounds_dan
it wont pull away with the side stand down. but if i put a positive up the start wire in the fuse box (yellow/red i think) then it will crank (the alarm splices in there). so atm if i press the remote start with the bike in gear it will jump off the side stand and roll down the road.
dan
Re: neutral wire
Posted: Thu Sep 20, 2007 4:01 pm
so by doing what you have you must be inserting a live feed after the sidestand switch, you need to connect it before .
Re: neutral wire
Posted: Fri Sep 21, 2007 10:15 am
by superman
yup, i would make sure all switches are working but it sounds like the stand an wires from the clutch are ok (doin there job at least) you need to look further in the bike for the rest i recon its a take the bike half apart joby, ouch. much easyer to leave the auto start out
