slightly poorly zxr400
paula w
My Bike: zxr 400 L1
Post by paula w »
The problem I have right now is when my bike reaches normal temp it seems to cut out at low revs or comes to a stand. Still. But it don't do it when its cold
Any ideas anyone?
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: slightly poorly zxr400
Post by Mori Man »
Most likely carb's are needing a tweak , if bike has been standing for a long period of time they might need cleaned - when was it's last service ?
Balancing the carb's might also help and again this goes back to - when was the last time it was serviced ?
Have the shims ever been checked/adjusted as they warm up gaps change so what worked when cold is not so good when hot ?
see a theme starting here winks
Check all the service parts, filter n plugs - if they are new/ good condition you can rule them out
Happy hunting,
MM!
Tirpitz
My Bike: Kawasaki ZXR400L4
Post by Tirpitz »
Could be running far too rich, so it runs fine when cold but gets choked up when hot. Check the choke isn't sticking on (both the cable operation and the plungers on the carbs) and also the air filter. If the filter is bunged up it will have the effect of making the bike run rich.
Quite a lot of things it could be but you need to have a benchmark to start from like MM says of knowing the bike is serviced and tip-top. Then you can concentrate on specific areas. If it's a pig in a poke you don't know where you are to start with.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
paula w
My Bike: zxr 400 L1
Post by paula w »
Hi thanks for the repliesmy husband has cleaned out the air filter and carbs. And checked the choke we have ordered new spark plugs too now. Haven't taken it out for a run yet due to the dodgey weather :( but hopefully will get out tomorrow.
Tirpitz I have seen you at sherburn a couple of times
Tirpitz
Post by Tirpitz »
paula w wrote:Tirpitz I have seen you at sherburn a couple of times
Well why didn't you say hello? I don't bite, honest :smt001 I think I prolly saw you arrive too once. I looked for you when I had a mozy around later and found your bike but no rider lurking anywhere near. You make sure you speak next time. I shalln't be there again until spring now, already getting cabin fever :smt013
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
paula w
My Bike: zxr 400 L1
Post by paula w »
Well I saw you before I got a zxr and was going to ask if I could sit on it lol but when I plucked up the courage all tht was there was your coat and helmet lol but I will come say hello next time :)
I can't get cabin fever I ride my gs 500 to work everyday
Tirpitz
Post by Tirpitz »
Ah, maybe it wasn't you I saw then. I deffo saw a lady arrive on a ZXR once (pretty sure it wasn't a fella with long hair :smt005 ). That's good in a way as the bike was, shall we say, hard done by so at least I won't have to be being all polite about a bit of a wreck when we meet. By the sounds of it your old man looks after yours well so I'm expecting a gleaming exhibit :smt002
Would be very nice to meet you, I'll drop you a PM when I'm going and if the pair of you are there we can say hi :smt001
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
paula w
My Bike: zxr 400 L1
Post by paula w »
Oh my husband keeps all our bikes well lol there is a couple of bits that need doing on my zxr nothing major just a couple of scratches etc he painted my wheels and they now look great.
Yeah let us know when your going next and we will come say hi. We are in donny too
