Casing is carbon composite and being lithium they are extremely light
Shop didn't have the LFX12A2 in stock but did have the A1, terminal position on these batteries isn't important as there is no oveflow tube to feed in a certain point. As it was this one was the correct way round.
Unfortunately it is too wide to fit into the battery box, no biggie as can modify that in no time
They come with oodles of foam packers so you can get them to fit snug but not needed on mine. Having the single seat cowl on I have no where to put the tool roll so actually what was a problem has turned into a good thing, will now make a lid to fit over the battery box area and keep the tool roll in there and give the battery a more solid surface to sit on.
They say the battery is 70% charged and is good to go, volt meter said it was 13.8v and the one on the bike said much the same thing.
Bike fired up fine, absolutely no hesitation and volt meter showed 14.2v at tickover , on the first day I saw this rise to just over 15v but for the most it sits at around 13.8v
The battery I removed had just been fully charged so there was no problem with it but I swear the new battery has given the bike some extra "zing" especially low down - wasn't expecting this so wasn't looking for it , could be it just has that extra oomph being new and it most likely will wear off
First starting issue was last night at it's favourite haunt, the supermarket ! Had been dropping by shops doing quick stops and start no problem. A lengthy ride to the supermarket with some fast sections going into residential , stop up and go in and do my shopping so maybe a 15~25min stop.
First press of button nothing happening, 2nd with some throttle still nothing, 3rd adjusting throttle and I am now set that it's just going to drain the battery and I am facing a walk home to let it go fully cold and then come back ( what I have done in the past ). Cranking rate hadn't dropped though so on the 4th I just let it spin adjusting the throttle and it caught
I had lucky dip vouchers that needed spending before the end of the month so it worked out at costing me only 25GBP for it
I can't whole heartidly recommend as of yet, haven't used it long enough to judge that way but my initial reaction is - it's here to stay and when funds permit all the bikes will get swapped over.
It has a 2yr warranty and the shop I bought it through will give me no problems if I do have issues with it so for me there is no risk and for what little cash had to come out of my wallet a very worth while try at latest technology.
On another forum a vendor has been selling them for a while and I have been monitoring what has been said about them there, only real issue seems to be cold weather starting but there is a work around for that allowing the battery to generate heat by leaving the ignition on for a while. Plenty users have GPS, phone,heated gear etc... also plugged into their bikes and haven't reported anything untoward. However do a search and you will find folks complaining about them but you can do that on anything - there will always be a set of people who praise and another who shoot it down in flames.
I have a 1st generation PS3 thats perfect yet there are thousands of posts of how sh!te they are
One of our LCD projectors was p!ss poor yet hundreds say its the mutz nutz
So make your own descision if you want to take the plunge , I will keep updating this thread over the months especially as we are coming into the colder winter weeks.
MM!
