Plugs and leads
stonemonkey
My Bike: Zxr400 L2
Plugs and leads
Post by stonemonkey »
Anyone if there are any aftermarket ht leads? Mine have split and separate from the plug end.. :(
thomp1983
My Bike: zxr 400 l3
Re: Plugs and leads
Post by thomp1983 »
you usually have to buy ht lead wire and the ends on your old leads screw off then onto the new length of wire, or it'd be a great time to fit stick coils and do away with ht leads completely
chris
stonemonkey
My Bike: Zxr400 L2
Re: Plugs and leads
Hmm I will probably go for the coil stick mod if a well priced loom and set of coils come up.
thomp1983
My Bike: zxr 400 l3
Re: Plugs and leads
Post by thomp1983 »
http://www.ebay.co.uk/itm/HONDA-CBR-900 ... 3a6bba2382
there cheaper than the set ive got and he'd probably take £30
chris
stonemonkey
My Bike: Zxr400 L2
Re: Plugs and leads
thanks, is the length and diameter a direct fit for the plug hole onto the spark plug? Are thay a tried and tested swap over for an L2 ?
thomp1983
My Bike: zxr 400 l3
Re: Plugs and leads
Post by thomp1983 »
after a bit of digging around google shows there the same part number as the cbr 600 ones i fitted to my bike so yes they should fit fine
chris
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: Plugs and leads
Post by Mori Man »
That's friggin cheap for that set-up , would need to pay almost that just for the used loom ! Same as I have in my H2
You do get Sunfire leads & caps which also have bonded earth straps on them - got a set in a box somewhere and as said you can just replace the standard HT with any modern kit you can find, copper or silicone core, car or bike - 7mm is ideal but you can squeeze 8mm in but the sealing gromits on the coils wont fit.
MM!
stonemonkey
My Bike: Zxr400 L2
Re: Plugs and leads
Put an offer for £28.50 in and it got accepted so they should be on their way :)
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: Plugs and leads
Post by Mori Man »
stonemonkey wrote:Put an offer for £28.50 in and it got accepted so they should be on their way :)
:smt004
Haven't done many miles with mine and it's got to be over 18months since doing and no problems or regrets :smt001
Got a set of sticks on the shelf for one of the next builds - just need to source the loom bit.
MM!
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: Plugs and leads
Post by Mori Man »
stonemonkey
My Bike: Zxr400 L2
Re: Plugs and leads
Some big variations in price there! Engine won't be going back in for a few months as it need a jolly good clean and paint. Cheers for the help.
thomp1983
My Bike: zxr 400 l3
Re: Plugs and leads
Post by thomp1983 »
i did have to dig around to find them at that price, i think i paid about £50 for mine, with the exception of my fireblade calipers there probably the best upgrade ive done they've helped make the bike alot more rideable at low revs (below 6k)
chris
