Alternative / Lighter wheels
AFM327
Re: Alternative / Lighter wheels
Post by AFM327 »
I've got ZX6r wheels on my bike too. The 180 rear Pirelli was only slightly taller than the 160, I think I took a half a turn of ride height out of my shock. The overall weight is less than the stock wheel with the 160 too.
Kirky Boy
My Bike: L4 ZXR400 RACER
Post by Kirky Boy »
are there any discs that will fit onto an 06 zx636 front wheel but still be 310mm for the zxr400 calipers? zx12 disc seem to be either 300mm or 320mm and the zx6 are 300mm, if i used the smaller discs would i lose out on braking?
gavinfdavies
My Bike: gpz500s d5, zxr400 L5
Post by gavinfdavies »
if you use the smaller disc there's a risk that once the pads wear, they'll touch over the edge of the disc when braking, at which point they won't work. not good
mick41zxr
My Bike: ZXR400sp
Post by mick41zxr »
For the discs I grabbed a couple of sets of zx12 rotors. For non wave type I mounted zx9c discs on zx6r carriers (same button pattern).
Got hold of a set of scales today & weighed my wheels,
Front zx6 y spoke with tire & disks 11.55kg (part worn Metzler K1 120/70)
Rear zx6 y spoke with tire & disk 12.8kg (new Metzler K1 180/55)
Front zx6 y spoke with wet & wave rotors 11.13kg (bridgestone wet)
Rear zx6 y spoke with 160 wet & wave rotor 12.12 (bridgestone wet)
Front old 3 spoke zx6 wet & disks 11.76kg (bridgestone wet)
Rear 400l with wet & disks 13.55kg (bridgestone wet)
Rear y spoke zx6 rim only 5.76kg
Rear H rim only 7.03kg
New Metzler 4.12kg 120/70
Worn Metzler 3.97kg 120/70
Worn Metzler 5.85kg 180/55
For comparison
Front 5 spoke magnesium marchesini with 320 brembo cast rotors 5.92kg
When I get a chance I will weigh some bare rims to be exact.
L 3 spoke from memory feels heavier than zx6 three spoke but at a guess would say a late model front zx6 is 0.6kg lighter & rear is 1.2 kg lighter
I was supprised that a worn front tire would lose 120g in rubber.
Regards,
MB
Kirky Boy
Post by Kirky Boy »
good post, lots of info.
Where abouts did you get hold of the buttons at? i can't find anyone selling them.
ancozxr
My Bike: ZXR 400 Track, FMX 650
Post by ancozxr »
So for my bike L, what wheels can be setup to rear?
ZX6 model, any year?
Racing for the fearless....!!!!
AFM327
Post by AFM327 »
ancozxr wrote:So for my bike L, what wheels can be setup to rear?
I haven an 05 ZX6r with a 180/60 pirelli on mine.
ancozxr
Post by ancozxr »
what needs to setup?
The rear disk must be from 2005 model?
AFM327
Post by AFM327 »
I haven an 05 ZX6r with a 180/55 pirelli on mine.
New spacers, I used a lightweight ZXR400 rotor and the stock brake setup. Here's the link to photos, viewtopic.php?f=37&t=12449
hoddie
My Bike: In between bikes
Post by hoddie »
So if '03+ zx6r bst carbon wheels are fitted, i need to mod spacers and fit zx12 (from which year?) wavy discs? Any other mods, such as calipers etc? (for an l series btw)
noelb
My Bike: ZXR4H , H'Berg , BMW R12S
Post by noelb »
Just finishing my install of a H2 swing arm and ER6 wheels to my H1 race bike
https://picasaweb.google.com/1017306200 ... 4204983554
Tend to race as a one man band so as many endurance racing timesavers as possible have been incorporated.
Rear caliper from a Yamaha moped, mount is captive on the arm (grubscrews on the underside) - if I was doing it again, I'd leave the caliper underslung, the 45deg and captive caliper means I can slide the wheel as far forward as I'd like to un-hook the chain from the spocket. Ledges either side and captinve spacers mean the wheel will stay in place with the spindle removed.Will be making a piece to fix the spindle to the RH adjuster block so there's one less thing to fall off. Added plastic ramps to the front paddock stand this weekend to support the wheel via the disks but forgot to take any photos.
400y
My Bike: ZXR400H1 GSXR600
Post by 400y »
noelb wrote:Just finishing my install of a H2 swing arm and ER6 wheels to my H1 race bike
3. Wheels:
Wheels must remain as originally produced by the manufacturer for the homologated machine except for the following:
Wheel bearings and spacers may be modified or changed where required. The speedometer drive may be removed and replaced with a spacer. The refinishing of wheel rims to a suitable standard is acceptable. 18” Rear wheel may be replaced with a suitable 17” rear wheel from the same manufacturer Front and rear wheel axles must remain as originally produced by the manufacturer for the homologated machine. Modifications can be made in order to accept safety retention devices
:tease
noelb
Post by noelb »
As long as on-one looks at the last few championship winners.........some funny wheels, funny forks, and some other bits. Not fond of the way those rules were written anyway. Someone needs to check whats involved in homologation before popping it into a rule book........ :smt018
Anyway - its a safety mod - my old wheels could have been cracked and aren't available new anymore? :smt002
Noel B.
For sale - two sets of H model wheels and front disks.............
400y
Post by 400y »
:excited
Nice work Noel. I like the ledges might even do that myself.
but your being a bit naughty with the ER6 wheel........................ oldman
