Does anyone know where I can purchase only the rubber diaphragm for 32mm cv carbs for my GPZ400r, spoke to cradleys and they were offering it with slide at just over £100, but just looking the diaphragm. Removed the lid of of the first carb and it was using an over sized diaphragm folded to fit? Dont know if this was effecting it performance but I want to get it replaced asap.
Thanks for any help in advance!
Monty
Diaphragms 32mm
monty0443
- My Bike: Gpz400r
Re: Diaphragms 32mm
It only ever comes as part of the throttle valve , posibly other 32mm CVKs will fit (just a different needle used).
Got a local scrapy you could take the carb or a good one along too? See what you can find.
The throttle valve here is 9,000 Yen + fees
BTW, I got that radiator cradle for you - just got side tracked
MM!
MM!
- extonyg
- My Bike: zxr 400 L1 uk
Re: Diaphragms 32mm
hello are you still after a diaphram? i might have a spare one if your intrested.
