Rebuilding fairing
Daniel.p
- My Bike: Zxr400 93
Rebuilding fairing
Right i crashed ages ago recked my front nose cone and the only second hand one i could get was well poor at most, it has half the indicator hole missing and i need to build the plastic back up because it looks soo tacky! I have a fibre glass kit but not sure if thats the best option for making the gap up thanks
Ride it like you stole it
Re: Rebuilding fairing
If you have parts of your original cut out the piece you need from it and weld it in using a soldering iron , a cable tie can act like a welding rod giving you some extra molten plastic to work with.
You can then use the fiberglass at the back of repair to strenghen it.
Once its all filled , sanded and primed it will disapear and ready to paint.
