bike stalls when i put the lights on
chrisI
Post by chrisI »
im in need of some help my zxr stalls when i put the lights on but will stay on when i put the revs up a little it wont stall and im not sure
what it can be
if any one can help this would be great thanks
Re: bike stalls when i put the lights on
sounds like your rectifier has gone, i take it it runs fine when the lights are off?
chrisI
Post by chrisI »
runs fine with the lights off.
il get a new rectifier and see what happens
Check the voltage across the battery while the engine is at 4k rpm, should be 14.5volts. Check the manual as there's a test for it. If its lower than that then yes a new rectifier is necessary.
chrisI
Post by chrisI »
does anyone know were i can get a rectifier as there around £65 on ebay is there anyware cheaper
thanks
