Indicators
vanman
My Bike: zxr400l
Indicators
Post by vanman »
Hi was wondering if anyone can help
I have micro indicators on my zxr (bulb type) not led which i have replaced temp with standard indicators for the mot
standard Rear ones went on fine and were checked with the front micros still in place to make sure they flashed ok and worked fine
so i moved onto the fronts took off the micros , wired up the standard indicators which just light up with the rears, which were happy flashing with the small fronts swapped over both standard indicaors and still do the same just light up and not flash so it cant be the bulbs when i plug in he front indys they flash ok so can anyone explain what could be going on
Many thanks
A DOG IS FOR LIFE NOT JUST A FRIDAY NIGHT
Re: Indicators
if the indicators just light up then seems like a bulb has blown, check all your bulbs.
