Jets are Keihin from following link, although i would say they arent branded keihin and not quite exact copies as they are slightly taller > http://motorcycleproducts.co.uk/catalog ... f5ade66a6azimm wrote:I would expect with the snorkel fitted for it to be leaner with the OE filterthetyrant wrote: i was wondering if i put in a stock filter with snorkel will it be richer or leaner than the k&n with snorkel ?
#98's sound about right with this setup, maybe even #100's
are your replacement jets keihin or dynojet ?
If its going to be leaner still with oe filter im wondering if i should stay with k&n and maybe try some 98's ? unless of course youve found its easier to get smoother power with oe filter than using a k&n ?....dont want to spend twice if you see what i mean, if i can get k&n to work ok i will stay with it but dont mind switching to oe filter if there is better carburation to be had
Ian
