Broken tooth
Fastforward
- My Bike: Zxr400 h1
Broken tooth
Hi all, i got a big problem.. In the process of fixing my bike up myself. The problem is my crankshaft sprocket has a broken tooth. Its a zxr400h1. Any ideas on what my options are? I dont think the sprocket is removable
Re: Broken tooth
I take it u mean the chain sprocket? It is replaceable, if u take the sprocket cover off, you'll see the sprocket with two bolts near the middle. Undo those and a flange should come off with them, it will need to be turned slightly to slide it off the output shaft splines. Your sprocket should slide straight off to be replaced by another.
Just note it is best to replace the lot as a set, ie new chain and sprockets all round
Fastforward
Re: Broken tooth
Thanks rob, sorry i meant the one where the camchain goes on..is that the 1 u meant?
Re: Broken tooth
Ahh! Umm, pass. Although something is telling me there's a hex bolt in the middle?
Fastforward
Re: Broken tooth
Lol thanks rob, the spare parts book from here shows it as part of the shaft.. Either way ill speak to a breaker around here. Just a question if u dont mind or whoever, what wud u think about leaving it as is? Any problems? Timing? Thanks
Re: Broken tooth
I wouldnt like to say to be honest, other than better safe than sorry.........
Fastforward
Re: Broken tooth
Ok fair enough, thanks for the help i appreciate it. Im down to the pistons but not really amped to go down deeper.. Will make up my mind and see what i go for..thanks again rob
Fastforward
Re: Broken tooth
Ok im considering another crankshaft, and i need my bike running asap. The next problem is that i can get 1 for a J or a L, otherwise a new 1 which would burn a hole through my leg! I know the J is very similar to the H, so is the crankshaft interchangable, considering a good balancing if needed? My pistons are standard and im not sure about my rods but they should be.
Re: Broken tooth
if it is only one broken tooth on the cam chain sprocket on the crankshaft I'd take a calculated chance and ignore it...........................I genuinely think it would be OK.
And certainly worth the gamble.......................versus the cost of replacing the crank and all that entails
Fastforward
Re: Broken tooth
Thanks cargo, thats what i was hoping..not interested in doing the crank or even getting it done. ill put a new chain on so if it doesnt go my way then too bad
wont hold anything against anybody. Thanks again
Re: Broken tooth
It might be a good idea to find the missing tooth and also how did it break
Fastforward
Re: Broken tooth
I bought the bike with problems, it hardly started and was rough as hell. I managed to get the bike starting first time every time and running good, as best as i could do without spending much. The revs hanged at 2000 no matter how i tweaked the mixture and there was a constant tapping noise. I was saving up to send it in when it seized on me. It was the camchain. Pistons and valves have carbon buildup but im cleaning that, otherwise they are good. Im getting another inlet camshaft for cheap, mine is well below service level and 2 cams are bumpy. Getting new rings, stem seals, gaskets etc.. I regret it but ill fix it, its just that sprocket that was bothering me. The tooth could have been broken before i bought it, ill still make sure though.
