Brumbrum, come home after a 3 mile test ride, turn it off..... try to start it again, and the battery's dead. Figured out the charging system is not working. Did the rectifier test (with 3 batteries + bulb) all fine on that test, did the regulator test (ohms/resistance) didnt like that at all, that didnt read squat on all but 1 pin. I can run the bike for about 5 minutes before a charged battery dies, how do i test the AC voltage of the alternator??? Where do i put the two probes, and what setting should i turn my multimeter to??
ps, new rectifier/regulator on way, just really want to test the alternator, voltage across battery when off: 12v, charging voltage across battery: 12v LOL
