workshop camera
workshop camera
just got an ip camera for work ..
you should be able to access it @ http://zimm.doesntexist.com:100/cam1.htm
username/pass is "guest" without the quotes ..
let me know if its working or not .. I'm unable to test it from outside the LAN here
Re: workshop camera
not working for me but that could be a problem on my comp....it says I might need to update my java scripts ? ? ?
Re: workshop camera
yeh, you need java installed .. sorry .. forgot to mention that.
try http://zimm.doesntexist.com:100
should give you a choice between java and activeX to display the images.. activeX only works in internet explorer, java should work irrespective of browser as long as your java environment/plugin is up to date.
Re: workshop camera
I'm installing java right now.................got it from here
http://www.java.com/en/download/inc/windows_new_ie.jsp
Re: workshop camera
funky !
tbh there's not much to see atm, its just covering the yard .. there'll be an internal one to follow if it all works ok.
Re: workshop camera
working fine now...........get out there and give us a wave :excited
Re: workshop camera
come on where are you ?????
Re: workshop camera
sweet :)
keep an eye on the dog while i nip to the shops then :pmsl
Re: workshop camera
ooooooooooooooooooooooo a car just went past
Re: workshop camera
who is that dodgey look guy and a dog too
Re: workshop camera
get a hair cut scruffy looking yob :pmsl
Re: workshop camera
Enough I've got work to do
Re: workshop camera
haha ..
working ok then .. lol ..
the bloke with dark hair is my neighbour .. im the shorter scruffier blonder one ..
Re: workshop camera
cargo wrote:Enough I've got work to do
+ 1
got this to install and setup :)
and a new exhaust to fabricate for my renault 5 ... the one i made yesterday (straight through) recorded 120Db at 2 metres ... shocking
thanks for letting me know its all working though .. appreciated.
Re: workshop camera
Nice compressor...........................
I've got a 3hp Sealey with a 50 liter tank. It's big enough meet my needs but not so big that it's not portable...............I take it to the IOM for the Manx very handy for keeping airbeds inflated. :pmsl
