EXHAUST FOR MY ZXR400-H2.
- My Bike: ZXR400-H2
Does anyone know where i can get a road legal or standard can for my bike???or if 1 of another model ( J or L ) will fit?
- BikerJake2010
- My Bike: ZXR400 L8 / XJ600 S
Re: EXHAUST FOR MY ZXR400-H2.
Check out the Pipeworx exhausts on ebay, I just ordered a carbon one... they have a removable baffle to so can be used on the track (or to sound good
) it just bolts str8 onto the orional pipework by the 3 bolts...
Hope this helps.
J
Hope this helps.
J
Er
i dont think mine is standard then, i have a slip on end can with a single clamp, is the standard can held on by 3 bolt at the bottom of the can then?
- BikerJake2010
Im not 100% sure for your exact model, but on my L8 it has 3 bolts on the bottom end of the can that fix onto the 4-2-1 origional standard downpipes... Some might be diffrent.. have a look tho incase but im sure you can order most of the exhausts for the zxr400 but ask for a certian size to slip on2 your pipe if its not the 3 bolts.
std cans have 3 bolt fittings, slip ons are aftermarket usually race cans. carbon can co i think do road legal slipons.
