Going to fit an AMS ram air box to my track bike. Heard i had to move the coils so it will fit proper. Is there any other things i should know before going ahead?
Cheers!
AMS RAM AIR BOX
- Ballsout Racing
Re: AMS RAM AIR BOX
You'll have to get the carbs set up, ideally on a Dyno.
Kirky Boy
- My Bike: L4 ZXR400 RACER
Re: AMS RAM AIR BOX
Cheers! probably be best to use a dynojet kit? heard of racers using the flatside carbs but i think i will stick with my cv carbs.
- extonyg
- My Bike: zxr 400 L1 uk
Re: AMS RAM AIR BOX
radiator has to be 'modded' or moved down and might want to remove oil cooler as well.....
Kirky Boy
Re: AMS RAM AIR BOX
Is the oil cooler not really needed? i take it you just plug the openings on the bottom of the sump?
- Ballsout Racing
Re: AMS RAM AIR BOX
No, you need needles and jets that match, I hear dynojet's don't actually always work. I understand that Flatslides can give good gains on a standard engine, but I know they don't give so much on a top well tuned engine. I still use CV'sKirky Boy wrote:Cheers! probably be best to use a dynojet kit? heard of racers using the flatside carbs but i think i will stick with my cv carbs.
- Ballsout Racing
Re: AMS RAM AIR BOX
Different opinions on this, my tuners do not recommend taking it off. Over heated oil = engine failiures!Kirky Boy wrote:Is the oil cooler not really needed? i take it you just plug the openings on the bottom of the sump?
- extonyg
Re: AMS RAM AIR BOX
there is another thread somewhere about removing or not to remove the oil cooler, ....... lots of people have lots of different opinions on this there are several ways........block off holes, someone used a bit of pipe from one hole to the other, and im sure i read somewhere that a zx4 sump fits on and it doesnt have the oil cooler pipe holes, but then other people dont think its such a good idea........so lots of ideas for you to decide.
