Hi
After racing little Ducatis for a few years looking for a change, so plan on doing EDIasia Formula 400†championship
I have got the bike and currently checking it over, so there are going to be a few questions to ask
The only thing I need is spare set of wheels for the wet but as I understand H and L models are all different.
How best way to work out what model I have got
EDIasia Formula 400
Re: EDIasia Formula 400â€
main difference between H and L is the frame................................
This is a H
and this is a L
There are of course more models and other differences like H model SP or L model SP
But the above pictures given you the basic difference between H and l
This is a H
and this is a L
- My Bike: zx7r / zxr400
If its the wheels you are wondering about, I have found that the rears fit the same, but the front wheels are slightly different. I have an L model but ended up with H wheels. The front wheel need a slightly deeper spacer to fit (opposite to speedo side). I found that it was about an extra 3mm. Using without, will try to pull the forks in slightly. I cant tell you any specific measurements as I dont have my wheels here. Hope this helps
