I know the cam chain can be persuaded to pass the pickup sprocket by ether brute force or filing the relevant piece of casing.
Can it be done in the frame? My understanding is it can but it's mighty akward to time up with the frame in the way.
Im also looking at doing both of the guides, the front one looks like it holds itself in place, where the rear one is bolted in. Which brings me to my next question, is that easily unbolted when in the frame?
the tensioner itself doesnt need to be replaced unless i want a newer stye one? AFAIK the older one is in there.
And in terms of disassembly, remove in this order:
Pickup rotor
tensioner
cam caps and remove cams
old chain
guides
remove old cam chain or use to pull through new chain?
Assembly:
new chain
rear chain guide
front chain guide
cams
time up
tensioner
Any hints or tips much appreciate, no doubt youll have something to say Cargo
P.S. im gonna find out prices soon but any ideas on the cost of the guides? the chain iirc is roughly 20 quid.
