Spark plug caps
Zulliz
My Bike: ZXR400 L1
Spark plug caps
Post by Zulliz »
Hi there
Some weeks ago my bike wouldnt start after work, and my first thought was that it was the spark plugs, since they probably havent been changed for years, so today i changed em. But then i noticed when i put on my spark plug caps, that 2 of them wouldnt really grab on like they should, so i started up my bike and it was only firing on 3 cylinders. So now ive decided to changespark plug caps and ignition cables.
Now my question is, the original spark plug caps are quite long, where do i find some that can replace them? if u know id like a link so i can see em.
Thanks in advance :)
Re: Spark plug caps
your options are -
buy new
put up a wanted ad on here in the classifieds section as someone here is bound to have a spare set
ebay
or a member here called falloffslowly who breaks ZXR's
have you tried making a fresh cut on the end of the cable and screwing the caps back on?
Chris1984
Re: Spark plug caps
Post by Chris1984 »
push down harder on them while wiggling,mine are the same but a firm press and you can feel them catch
Zulliz
My Bike: ZXR400 L1
Re: Spark plug caps
Post by Zulliz »
RedexRobB wrote:your options are -
buy new
ebay
Hmm id like to know which ones i should buy if i opted to get new ones?
Chris1984
Re: Spark plug caps
Post by Chris1984 »
just ring cradleys and tell them what your looking for
Re: Spark plug caps
buy new
ebay
If you goto a kawasaki dealer they should be able to get them if they have the parts book. If you not then check out the microfiche manuals for the part number and take that in and there shouldnt be any reason why they cant order it.
http://www.zxrworld.co.uk/zxr400/micro.html
