Ignition
SixOne
My Bike: ZXR400
Ignition
Post by SixOne »
Came off my bike yesterday in a relatively gentle low-side, bike was still running when I picked it up but I turned it off to sort myself out. Now I can't turn it on, I have lights on the dash and a rear light but the electric start won't do anything at all. I've checked as many of the connections as I can and they all seem to be ok, does anyone know whether it's likely the started solenoid will have been damaged when I dropped it? I've got no front light either and the bulbs are fine and the connectors seem to be ok so I'm assuming this is a problem with the relay as well? But my main worry is the ignition, anyone got any ideas? Tim
Re: Ignition
kill switch off?
if you can, short the terminals across the starter motor. If it spins you will at least know that its an electrical problem and not with that starter motor. Which side did you drop it on? I think the starter solenoid is sat on the left hand side of the bike and its possible that its been squashed by the seat panel in the fall.
Mad Phil
My Bike: Hayabusa, Ducati 996SPS
Re: Ignition
Post by Mad Phil »
I know it sounds stupid but have you checked the kill switch position....
It does happen winks
Mad Phil
Re: Ignition
Post by Mad Phil »
Dam you beat me to the kill switch idea... :smt010
SixOne
My Bike: ZXR400
Re: Ignition
Post by SixOne »
Went down on my right hand side, so I guess that would be unlikely in that case. Yeah, checked the kill switch! As I said, got power elsewhere just won't do anything to start, will try and get the starter motor to turn as you said and hopefully I'll have some idea then! Thanks, Tim
extonyg
My Bike: zxr 400 L1 uk
Re: Ignition
Post by extonyg »
check the fuses there is one on the starter/ignition relay make sure its ok and secure.
Mad Phil
Re: Ignition
Post by Mad Phil »
Tried bump starting to eliminate the starter motor..
