1. The bike is 'hunting'. (Have cleaned the carb's to within an inch of theirs lives)
2. Very poor throttle response. If you twist the throttle it takes close to 2 seconds for the bike to reponsed. Thought it was the cable but its snapping on the carb's as quick as i'm twisting.
3. Want to try a sealant between the carb mounts and the cylinder's. Will a high temp. liquid gasket do? I need to re-seal the altenator cover anyway
All the shims, timing, etc was all done before i crashed and the bike was running spot on.
Help???
