O Rings in the inlet rubbers
When replacing the inlet rubbers on the later models, do people...
Replace the O rings, no sealant
0
No votes
Replace the O rings, use sealant
2
50%
keep the old rings in, use sealant
2
50%
take the old rings out, have no rings, and use just sealant
0
No votes
Total votes: 4
parby81
Post by parby81 »
Just wondering what people do when replacing the inlet rubbers
Re: O Rings in the inlet rubbers
Are these the rubbers for the carbs?
if funds allow then replace the o-rings, at the end of the day if you are replacing the rubbers then you must be able to afford the o-rings as well.
parby81
Post by parby81 »
I Agrre rob, but if your replacing the o rings, and technically they should be nice and supple etc then why the need for sealant as well?
Yes we are talking about the carb rubbers
where did rob say anything? :smt017
parby81
Post by parby81 »
sorry baz, getting confuzzed, reading to many posts on here. Plus, Rob normally has something to say :)
Dont the o'rings come with them? :smt001
parby81
Post by parby81 »
nope, at least didn't when i ordered them. Of course Cradley's didn't tell me that over the phone.
just checked the fiches and they are a seperate part, looks like youll have to get them seperately. You could just use sealant, blue hermatite does i think.
parby81
Post by parby81 »
i've used sealant and the old O rings. Can't remember what its called, but its supposed to be oil and petrol proof. Revs still hang though once its warmed up. Can't think what else it'd be now.
well this is the problem i had with the zxr750 and i tried everything, it wasn't until i sold it that someone commented on a thread on here about altering the mixture screws so give that a go.
the clamps for the carbs done up tight enough?
parby81
Post by parby81 »
yep, only 2mm on each one, though they still seem to move about a lot (but i think that is just the new soft rubbers).
Fiddled with the mixtures no-end. Doesn't seem to make any difference. To the point I had each turned out about 3 - 3 1/2 turns and it still hung. Thing is, if you let the clutch out so it just bites, the revs drop back down to about 1300 and stay there. its not until you blip the throttle again that they will hang.
Runs fine when its cold, its only once it warms up, and its only at idle. No other flat spots through out the rev range. Just one of those annoying things I haven't been able to figure out!
Snagging cables? Are they well lubricated? Also make sure that the throttle returns fully by checking it stops against the throttle stop. Worth giving the carb springs a bit of oil too id say.
parby81
Post by parby81 »
Tried all that rob,
Bar getting new cables, they are well lubed, hit both stops freely, plus if you remove the cables and just move the throttle on the carbs by hand it still does it. The carbs have been sprayed repeatedly with carb cleaner and oiled, so i don't think that would help (plus exactly the same even with different set of carbs). Thing is, it does it airbox on or not, and when its hanging i have physically pushed on the carbs, throttle stops, made sure the choke is fully in etc etc and they all make no difference.
The only differences I ever get (having replaced the head gasket, timing chain, new set of carbs, air filter, inlet rubbers etc etc) are higher up the revs i.e. elimination of flat spots and with the replacement if the timing chain (timing is now spot on) and better drive. But no matter how much better it gets throught the rev range I still always have this hanging. Yet as soon as you ask someone they immediately say air leak or mixture. Stumped mate
