So out with tools and got it stripped
Because I'm building my bike from the ground up I am re-setting the clocks to zero, however the trick is not to set the tumblers to zero as you will find that the majority of them "float" about and when you start clocking up the miles they don't align right.
What you do or what i have done is set them to 99,999.5 miles , the 1st ride out I will cover at least a few miles so they will clock themselves back to zero - this mechanical movement should make them all sit OK
I have taken some photos to show how easy it is to dial in the tumblers, a cocktail stick and your sorted - getting the clock apart isn't so lol !
Later......
