The new missus and her new rear end! ZXRS400
Re: The new missus and her new rear end! ZXR400RS
nice one, nice to see people putting different back ends on the zxr!
- Marcie
- My Bike: ZXRS400, CBR600
Ahh some more upgrade's for my ZXRS400!Namely, twin horn... they sound manly, non of this girly toot business. Sort of like a van haha, still 200 times better than normal.
And then an additional rear caliper, a gold brembo one
the rear brake now has a lovely progressive feel then if you push all the way it stops like the front does, it gives alot of feedback and stops my 100% reliance on the front brakes. I must say this was a cosmetic thing, until i actually tried it!
So simple to do both of these mods!
Yeah MOI the rear end of the OE zxr400 is not too my liking, and i think to a considerable ammount of owners. Just shows it can be done.
Marcie
Marcie
Some body once told me... Theres only two things in life you'll ever need, Gaffa tape and WD40.
If it moves and it should'nt use Gaffa tape, if it doesnt move and it should use WD40!
- Marcie
Re: The new missus and her new rear end! ZXRS400
Strike that, its got THREE horns now... my goodness, it doesnt scare old ladies but deafens them!
Oh and ive got a daytime running light hooked up to the dipped beam now, a home made one ofcourse. Ill get pictures up ASAP.
Consists of a LED torch taken apart took all the stuff it didnt need off which just left the LED's which are red/blue/green and some other colours which flash and rotate, with bright white ones all around the outside which stay on, mounted under the front fairing bolt.
Marcie
Marcie
- CBT slow
- My Bike: zxr400 H2
the new nightrider? lol
- Marcie
Haha just a bit!
- My Bike: Yamaha R1
Is that safe with 2 calipers bolted to the disc?
I remember recently that a guy was jailed after putting his 4x4 into a river and killing a few of his kids cause he had "modified his brakes"
- Marcie
Haha good point mate, does it look safe?
Not entirely but thats not the point, back brake is like 0 percent of my braking.
Im going to make a propper bracket soon just because you brought it up.
Dont think id be killing my bairns though, although if i kill myself maybe im killing future bairns, ahh i see where your coming from!
If the calipers were 'bolted to the disc'... that would be DANGEROUS!
If i dont post for a while you can close this thread due to dangerous bodging.
Marcie
Marcie
Marcie wrote: If the calipers were 'bolted to the disc'... that would be DANGEROUS!
If i dont post for a while you can close this thread due to dangerous bodging.![]()
Marcie
- Marcie
If you didnt play around with ya bike and make it your own...
You would be a 2000 mp/y sunday rider
and that we are not.
Marcie
Granted if your playing does cause death ... walk away from the cable ties!!!!!!
Marcie
- CBT slow
how did you manage to connect both hoses mate? did you use a splitter thing like the front brakes have got?
- Marcie
I had quite a long bolt (well both banjo's fitted on with about 3 threads spare) from another brake M/C so....
I drilled a second hole further down the bolt and shaved off a thinner diameter, if youve ever seen the bolts you'll know what i mean.
And essentially theyre stacked on eachother. (My mate broke an after market bolt on his master cylinder the other day so i took the time to drill an average bolt through the middle and in one side and shaved off a thinner diameter, his previous bolt was drilled all the way through, hence it broke.
Marcie
Marcie
- CBT slow
ahhhh i see, wouldnt i be better to use the splitter thing(cant remember its name)? then at least you knew even pressure is going to each caliper
- Marcie
Probs. I was thinking of using another M/C mounted side by side with the existing one. But then i came across this bolt and thought id give it a go, works lovely. Seems even and progressive.
Ive ordered some metal cutting bits and bobs and drill bits to get a propper bracket made.
Marcie
Marcie
who needs soo much back brake? i find that a stock zxr brake locks up nicely if u slam on ...
so why 2?
so why 2?
- Marcie
Its apperance, and the fact i didnt want to slam the back brake on and lock, much prefer to have a progressive feel.
Dont worry though... all has changed now!
Pictures to follow!
Marcie.
Pictures to follow!
Marcie.
