cdi
Re: cdi
Why would you want the rev limiter removed? More revs does not necessarily mean more power. For instance our race bikes are tuned and we use standard CDI's because peak power on the Dyno is at just under 14,000 revs. It is pointless to take the engine above this as we would not be using best available power. Your best bet is get you bike dyno'd for about £35 and see where your peak power is. Having your jetting set properly will give you more performance. Then you can discuss with the dyno peeps what else they can do for you. Or talk to the likes of Bob Farnham the tuning specialists or Andy at Dynotech in Basingstoke.leon#51 wrote:Hay folks whos the best to get my cdi done? Im wanting the rev limiter moved cheers leon.
