Shimming
shall we keep a stash?
yeah great idea
10
100%
no buy your f***in own
0
No votes
Total votes: 10
Shimming
following on from MMs valve clearance thread ........
Mori Man wrote: If the exchange rate hadn't freakin collapsed so much i would of been happy to supply shims at cost to make a forum "Stash" . They only cost 704 Yen here which used to be under £3 but that's now £5.42 shocking
So,
Gather names up on who does their own servicing and rather than you all have a box of shims each, make a collective set. At times you'll need to top up the most popular sizes that are used and you'll end up with bundles of another size - can't be avoided!
But over all you should all save on servicing costs. You can make a rule that when you have the stash and after completing servicing you empty a particular size of shim you replace them with two the same size ensuring that when it's passed on there is always a full set of numbers.
From my own measurements it seems 2.90 , 2.95 & 3.00 are the most common so doing a group buy on a bundle of 2.85 & 3.05 might be helpful. In my shim box I already have a collection of 3.15 & 3.10 so expect these to be the growing number in your stash
Just a thought!
anyone interested in having a stash of shims for forum users ? i am happy to collect the shims if everyone wants to send me any unused spare ones?
stug
My Bike: Yamaha R1
Re: Shimming
Post by stug »
I have 2 spare, send me your address and I will post them on.
Re: Shimming
It's an excellent idea as long as they fit the ZX9R! :smt003
Re: Shimming
Jamz wrote:It's an excellent idea as long as they fit the ZX9R! :smt003
would you believe they do?
what years your zx9? just checked and a 1997 uses the same shims.
Re: Shimming
If the '97 ones are the same then I'd expect all the B models from '94 to '98 to fit?
Mine's a '99 C2 so at least the '98 C1 models should fit, and possibly more.
A shim's only a little metal disk, though, so I should imagine a lot of them will be the same at least for Kwak's?
Re: Shimming
just checked C models use the same shims too mate
Re: Shimming
stug wrote:I have 2 spare, send me your address and I will post them on.
received mate! thanks for starting off the zxrworld shim collection, never seen one b4 :smt002 thought someone had sent me some watch batteries :smt005
how do you know what size they are? i thought they were marked up?
stug
My Bike: Yamaha R1
Re: Shimming
Post by stug »
I should have written down the sizes.
The sizes wear off the shim so they need to be measured.
From what I received from Kawasaki there is only 2 numbers on the new shims with the numbers being the last 2
i.e a "295" is marked as "95"
Re: Shimming
not a problem i'll stick a vernier on them as they come in.thanks again mate.
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: Shimming
Post by Mori Man »
Done some digging so if you have the following bikes it's worth your while joining the collective as they all use the same shim - not a definitive list BTW, just when i was doing other bit's n bob's :smt002
ZRX400
ZXR750
ZZR400
ZZR600
ZX9R
ZX636
ZX6R
ZX7R
If for some reason your looking for smaller shims than normal then
ZXR250
These run from 1.2 ~ 2.4mm
Done a shim check on my ZRX400 today and only two clearances I was happy with the rest all need done - thankfully I have my wee stash from the ZXR motors so only need to buy 5. I do however have a pile of 3.0 and 3.1 so I might just send some over your way :smt002
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: Shimming
Post by Mori Man »
Can't go wrong with this price for shims, but still sensible to contribute to a stash
http://www.zoomfactory.co.uk/valve-shimming-info.asp
ZXR are 7.48mm in Diameter
DannyMcCann
My Bike: (1990) ZXR400H
Re: Shimming
Post by DannyMcCann »
Even though it says KXF 250/450 they will work fine on a ZXR then? AFAIK shims were £10 each, and mine are as good as havent been done in the 21000 miles its covered :rant
edit - http://www.zoomfactory.co.uk/products.asp?cat=169 Will the top product be good as well then, as its still 7.48mm? I know I wouldnt need most of the sizes buts more for time cost of replacing them, obviously with them out of the engine I cant use the bike for work so if Ive got some ready in a box to replace after that can do the £3 each thing, or if the stash has the right sizes contribute to that :excited
Re: Shimming
what ?? you intend to raid my stash of 2 shims? :smt005
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: Shimming
Post by Mori Man »
DannyMcCann wrote:Even though it says KXF 250/450 they will work fine on a ZXR then? AFAIK shims were £10 each, and mine are as good as havent been done in the 21000 miles its covered :rant
Yip it's fine that it says KXF they will still fit.
Box if it contains 82 shims works out at 95p each :smt001 But you will be left with so many that will never ever be used I would say keep clear.
Even if all 16 shims needed to be bought your only £48 but more likely than not you'll swap a bundle about and end up only needing to buy say 5 .
@ MOS , Will be buttoning up the SP motor soon and after that i'll send you out a bundle to increase your stash man :smt002
Re: Shimming
Going by the shims i bought a few weeks back, the prices depended on thier sizes. That box of shims isnt bad value at all, but like you say, there will be sizes you'll never need.
