Spark plug puller H1
Cloud Wolf
My Bike: ZXR 400 L 92
Post by Cloud Wolf »
Ok i seem to be a moron, cant seem to find the right size to get the plugs out of my brothers H1, could someone tell me the size needed and wether it needs to have extra thin walls?
Re: Spark plug puller H1
it needs to have extra thin walls mate as the recess tapers, and i think they are 12mm. You also need one thats got the rubber cap inside that grips the plug. Otherwise its a fidly job wth a pair of long nose pliers.
Cloud Wolf
fucking monkeys, ok thanks Rob, oh i think i have top yolk nut from both H and L so will go check now. 1min
i always use one of them telescopic magnet tools to pull the plugs out, so much easier than fiddling with long nose pliers.
MillaMeter
Post by MillaMeter »
Hi,
Easiest way to get the plugs out once they're undone is to just stick the HT cap back down the hole, push quite hard so you hear the HT cap clicking on the spark plug, then just pull it out.... vwala! I have about 8 spare HT caps loose, so I just stick 1 of them down there instead.
Regards
Rich
surely pushing on the plug you're gonna risk closing the gap?
parby81
Post by parby81 »
yeah but if you're pulling the plug out then you can check and adjust anyway. Plus if all you've done is undo the spark plug, the electrodes are still normally in the whole and its just tilted to one side. I do both long nose and ht caps, ht cap never seems to close the gap up on me. Maybe if you're MONGO, and a tad ham fisted it might! 8)
