Whats the difference between an zxr4 import & Euro made bike
86zxr01
My Bike: zxr400
Post by 86zxr01 »
Hello all,
I've just got myself a 2001 zxr 400 l9 smiler (well I will do in a few weeks)........import. Does anyone know what the difference in power is? Am I going to be dissapointed by it? vsad Be honest?
+ any other info on this topic will be hugely appreciated biggrin
Re: Whats the difference between an zxr4 import & Euro made bike
Power is the same no difference between an import L9 and a UK L9
It will however be limited to 110mph...........................but it's easy to overcome.................
CarneyUK
Post by CarneyUK »
cargo wrote:It will however be limited to 110mph
As long as it hasn't got 33bhp restrictors in (seller should be able to tell you) it'll get there bloody quick though.
Only other thing is the headlight and clocks. If you have bought it from someone in the UK and it has been in this country for a few years you will porbably find the headlight has already been changed so it points in the right place.
The other is the clocks may be in KM's. Not a problem and you can buy stickers for the clocks off ebay (about £2), or get a converter (more expensive at about £30) that attaches to your front speedo cable at the wheel and converts the speedo. Advantage of a converter is it will stop you being restricted to 110mph as the clock thinks you never get that fast. Also the tacho will mean you don't put as many miles (km's on the clock)
i think the carb washers are a UK restriction and euro restriction is done via the speedo sensor...
i could be wrong,
86zxr01
My Bike: zxr400
Post by 86zxr01 »
Thanks people. Its a relief to hear these things. :excited When I get it I'll put some pics up.
Jack
you may find this thread interesting. viewtopic.php?f=55&t=2289
