AAAHHHH &%cking fuel tank!!!!
CarneyUK
Post by CarneyUK »
Thought I would start the bike again to get it warm to see if the fan was now working and thought it would be a good idea to check the fuel level!
As I turned the key it snapped :wanker and I can't get it out now. I feel jinxed with this bike!!!
:smt013 :smt010 :smt013 :smt010
Re: AAAHHHH &%cking fuel tank!!!!
soak it in wd40 and use a magnet to pull the broken key out
can you tell ive done this before ?
CarneyUK
Post by CarneyUK »
zimm wrote:soak it in wd40 and use a magnet to pull the broken key out
That won't work now! I've smashed the toad out of it with a screw driver after getting red mist!! :smt013
Can you tell I've got a short fuse :smt003
CarneyUK
Post by CarneyUK »
Managed to get the fuel cap off.....using a screwdriver, brute force and not a care in the world.
Seen a new one at Bitz for Bikes for £40 with keys. If I can't get one before or cheaper than that then that is what I will get!
Vard66
Post by Vard66 »
A new ignition barrel from Busters is only £34 anyway, so if that's a bit shot as well, why not get a new barrel and fuel cap set?
Vard.
_________________
1997 Volvo 850 R
CarneyUK
Post by CarneyUK »
Vard66 wrote:A new ignition barrel from Busters is only £34 anyway, so if that's a bit shot as well, why not get a new barrel and fuel cap set?
Looks like I may have sourced second hand ones anyway. :excited
Vard66
Post by Vard66 »
Bonus!
Vard.
_________________
1997 Volvo 850 R
CarneyUK
Post by CarneyUK »
Thanks to Baz and Jake I now have the parts I need to get the bike into Nick's to get the carbs done. Hoepfully it will go in this Saturday.
Thanks gents.
Vard66
Post by Vard66 »
Good stuff, Cass. Mayhap you'll get to go for a bit of a blast before the foul weather really kicks in, hm?
Vard.
_________________
1997 Volvo 850 R
CarneyUK
Post by CarneyUK »
Bike is now in Nicks garage. He asked me what I wanted done and I told him get it to work properly :smt003
I have adjusted the chain, put the new tank cap on, new seat lock, new clutch cable and a few other bit's.
He is gonna do all the engine and get everything done like carbs, valves and shims etc. He will have it for 2 weeks to give it a good checking over. Can't wait to get it back and get it through that rev range :smt003
