SINGATINI wrote:just swapped my motor for one that works....
now the rev counter is red lining at 1/4 throttle in top notch?
are they different rev counters for engines or is it some other problem
i still have my blown motor if i need to swap anything
i have noticed a slight difference in engines where the clutch cable adjuster bolts in...
and i have mass clutch slip
just reoiled with 10 40 castrol ful synth power stuff?
any ideas please on any of the above
My god that's a hornets nest of problems.............
OK I am not aware of any real difference in the clutch cable bracket from model to model
Tell me did you remove the clutch cable bracket from the engine? and in doing so slacken the camchain tensioner bolts ?
You may have created a serious canchain problem if you did
Sound like the reving is a trapped cable check your routing
And Castrol 10/40 full synth oil ......................was it the car oil? or the bike oil?
Fully synthic oil can cause clutches to slip very badly...........IMHO if you chose to start using fully syn oil then it needs to be a bike oil and you need to fit new clutch plates as well ...........my logic is that fully syn oil and semi or mineral oil soaked clutch plates are not compatible...................OR
it could be just that the clutch in your new/replacment  engine is fecked.
