I've had enough...
Re: I've had enough...
parby81 wrote:Thats what i meant. if the cables were to stick then the engine would continue to rev freely even when your hand was taken off the throttle as it would not return.
masterofinsanity wrote:the throttle has to operate smoothly, not stick and return to its idle position.
Surely this could be interpreted from your post as to be merely the mechanical movement of the throttle grip as opposed to when the engine is actually running.
:smt017 you've lost me :smt005
parby81
Post by parby81 »
lmao!!! doesn't seem too hard to do that
nitro_rhys
Post by nitro_rhys »
when i brake hard on my zxr such as someone pulling out or traffic lights changing the revs dont drop as fast as the bike slows down so when it comes to a stop the revs are a little higher than they should be, but then after 1 - 2 seconds they return to normal. Any ideas?
thanks
Rhys
MillaMeter
Post by MillaMeter »
Hi,
I think you'll find either 1. the carbs need balancing or... 2. the mixture is too lean.
Take the tank off and set it down somewere, buy some 8mm fuel line and run it from the tank to the fuel filter, turn the engine on and try richening the mixture by turning the mixture screws out 1/2 a turn each then see what she runs like. Give it a couple of blips etc...
Regards
Rich
my L1 did exactly the same as what yours is doing, and the carbs were replaced and balanced and still the same.
didnt bother me
