snapped spark plug
james zxr400
snapped spark plug
Post by james zxr400 »
riding home from work tonight dropped it down to over take a car then it just went flat and sounded like the exhaust had come loose. slowly got it home took it apart and found number 2 spark plug had snapped completely off leaving the threads in the barrel. with a bit of luck managed to get the rest out. without taking the head off. how many zxr owners have had this problem
Re: snapped spark plug
this has cropped up a few times lately, how did you remove the threaded bit?
james zxr400
with a stud extractor in a socket on a long extension bar ans a little bit of luck it came out
and did you check where the postion of the piston waS when you did this and how much fell into the bore??
james zxr400
i made sure the piston was at the bottom and no bits fell in. it runs a lot better now all 4 spark plugs are working
