I'm about to change the oil and although it's possibly the easiest thing to do, I was wondering if there are any tips or tricks with the ZXR?
Is there a mesh filter or anything like that? Or is it simply a case of:
Filler Cap
Drain plug
Filter change
Plug
Fill (3.0l)
I know this sounds stupid - I've done countless oil changes on cars, but this is my first bike engine oil change so I don't want to miss anything out and f*** my engine. For instance, I intend to stab the filter with a screwdriver to remove it (unless I find my remover). Am I likely to stab through something important? I've never knwon this method to cause harm before, but then again I've never known that many engines!!
Oil change tips?
- crushedlizard
- My Bike: ZXR400 L2
- deviant
- My Bike: ZXR400 L3
Re: Oil change tips?
No different to anything else, I've screwdrivered the filter off before, although I've now bought a thing for getting lids off jars - very cheap and works better than the stupid chain filter wrench I had before (which was the reason for screwdrivering).
Getting the filter off is a bit awkward, just because of the fact it's on the front of the engine behind the downpipes - so be careful if you've warmed the engine to make the oil come out easier. Also you *will* drop oil on the downpipes which will smoke a bit afterwards.
- crushedlizard
Cheers. Didn't think there'd be anything special but I thought I may as well ask.
She purrs now and has lost her unnerving rattle. The sump plug was a bit of a toad to get off but a 5' improvised breaker bar sorted that!
Just for future reference - is there a trick to getting the crush washer off? Or do you just mangle them off?
wtf is a crush washer?
- My Bike: zx7r p6
