dodgy rev needle
				kion
 - My Bike: zxr400
dodgy rev needle
The rev gauge needle is playin up, sometimes its fine but sometimes it is like saying 6rpm when its realy 3 rpm???
									ride with pride
Re: dodgy rev needle
Thats a knackered battery mate. Its come up a few times now.
id also check your regulator while your at it.  Best way is just stick a multi metter over the positive and negitve on the battary.  If you get more than 16v odd then you need to change your regulator
				kion
 - My Bike: zxr400
ok will the battery need replacing or just charing>?
Also had another prob, it wouldnt start up, made a funny buzzing noise and when i bump, it just missfires and doent wnt to run???
ride with pride
sounds like your battery is shorting, you will need to replace it. just check the earth from the battery is not corroded, take it off and clean it up with some emery cloth.
				kion
 - My Bike: zxr400
nah anything that'll get rid of the corrosion, wire wool, wire brush etc
				kion
 - My Bike: zxr400
hi, there was no corosion, there is a clickng noise coming frm the junction box when i try the starter?
									ride with pride
try running some jump leads off a car to your battery and try starting it.
				kion
 - My Bike: zxr400
depends, if the battery has died of death due to old age it should fire up ok, if the battery is breaking down and shorting it may cause same symptoms.
				kion
 - My Bike: zxr400
				kion
 - My Bike: zxr400
sorted, starts fine, ther was fluid around the posative terminal, and it stunk of hydrogen gas every time i tried to start, so it needs a new battery, and my hands sting lol.
									ride with pride
						- carsounds_dan
check the voltage output of ur regulator with a multimeter,
its in the manual how to do it, as the seal battery of the zxr should never leak unless its blown its top.
dan
dan
...i know, it's great
