Got my new zxr 400 but i dont think it will do 130 cause on the motorway i am doin 120km at 9rmp??
theres no rev restriction cause after 10k it goes rapid.
top speed restriction?>?
kion
- My Bike: zxr400
ride with pride
Re: top speed restriction?>?
Check the back of your clocks mate, if its restricted the speedo will be plugged into the loom.
- deviant
- My Bike: ZXR400 L3
I don't think the issue here is a restriction.kion wrote:Got my new zxr 400 but i dont think it will do 130 cause on the motorway i am doin 120km at 9rmp??
if you are doing 9000rpm at 120kph (i think that's what you wrote?) then there's something wrong.
120kph is about 75mph, and a standard bike would be doing about 7500rpm at that speed.
your bike might have been downgeared, but it would have to be very extreme to give you 9000rpm at 75 - something like 13/50, which is just about possible but very unlikely.
is your clutch slipping?
kion
- My Bike: zxr400
Whats the loom??
clutch isnt slipping, will check the sprockets as well.
ride with pride
The loom is basically all off the wiring on the bike. There should be a wire that comes out of the back of the speedo and plugs into all the wiring.
