I have read on here about stopping up the air corrector jets when running an aftermarket exhaust. I have a micron and road legal micron can. When warm the bike would bog ever so little if I really opened the throttle quickly - quicker than possible from the seated position.
But also around the throttle area where the idle circuit was just switching over to the needles to provide the fuel, the throttle was like an on/off switch and engine braking was big.
So I've stopped my air correctors up this afternoon and set my pilot screws at 1 1/2 (which seemed the best position). Bike seems alot better now, the engine braking is reduced and throttle is smoother, not how I'd like it ideally but smooth enough. All was well on my ride, then odly at temp lights the idle dropped to the point of it stalling. It seems when I blip the throttle now from idle the revs dip below the point I have them set at, then pick up again.
Anyone else expericened this? I could muck about with it myself but its such a fag to take the rears off, then the tank, then the airbox.
Set up with micron system.
Northern ANdy
- My Bike: Unique ZXR400
Northern ANdy
Re: Set up with micron system.
the only thing i know about jets mate is they are red and fly in groups.sorry!
ratbag56
- My Bike: zxr400 / 636
have u got any photos of wot u did? i put a dyno jet kit on mind but it still has the same problems u just said?
Northern ANdy
well I took them back out today, I think I prefered it with them in. I'd forgotten what it was like, it positively howls up to red line, pulls much harder, but the on off switch at idle jet/needle and needle/idle jet has returned, which is a clown. Don't know what to do.
Andy
Northern ANdy
completely lost a cylinder today. Missing all the time, have now put washers under my needles while I was sorting the misfire, will let you know how it goes.
Andy
- jake
are these air corrector jets the inner of the 2 jets on the top of the carbs?
i had these blocked with small pieces of wire when i got my racebike... did'nt know why they where there , so i ripped em out. runs fine now, but never ran it with them in tho....
Northern ANdy
no they are at the bottom of the carb mouths, the upper and more central ones out of the pair in each carb.
Re: The washers, runs alot better for raising the needles.
Andy
