Engine Timing
Guest
Engine Timing
Post by Guest »
Morning All,
can cam timing result in the engine not starting?
I still suspect I have a fuelling problem or just a very stubborn bike as it hasn't run for about 5 months, Turns over on the starter OK with no clunks or rattles and occasionally coughs and ticks over for all of about a second or so but then dies.
All ideas/ guesses gratefully received!
sloweracing
timing
Post by sloweracing »
i would say but not 100% but if it was one tooth out you will punch a valve throw the piston ?
my tuner 01732 463658 lawerence monday to friday 9/5
our you could put a post on this website and you will get a answer within a hour
http://www.motoforum.net
hope this helps i would wait till i get a answer if i was you
have you checked if you have..
a spark / try some old plugs
fuel pump should be ticking if you drain a bit out
check carbs are opening
sounds silly check fuel coming out of tap
ic igniter trouble
wiring shorted or open
fuse blown
ignition or engine stop switch fawlty
have you stripped or played with the bike retrace your steps
some times the side stand wiring plays up
that should keep you busy
do you live nr brands hatch :cry:
Ballsout Racing
Post by Ballsout Racing »
Yep, you can definitly run an engine with one tooth out on the cam timing.
You can even race it, but will wonder why you are struggling to keep up with some of the others, but not all of them :lol:
sloweracing
ENGINE TIMING
Have you had any joy yet
Guest
Post by Guest »
Ok lads, thanks for the advice. I know the plugs are sparking, but will be checking the fuelling first and then working inwards from there. Just prey to god it's not the timing,
Going to have a stab at it between Xmas and new year so will keep you posted as to any developments/ explosions nearer the time.
Cheers..
Guest
Faulty Starter Motor Relay??
Post by Guest »
Good news! the bike runs!, replaced the fuel pump relay (many thanks si!) and after many many attempts it's up and running. HOWEVER, despite a new fully charged battery the starter motor will only just turn over, if you bypass the starter motor relay (or whack it with a hammer!! - no really it works..) then it turns over at the right speed. My guess is a faulty relay on the starter motor but has anybody else experienced this type of problem??
Oh and if anybody has a spare starter motor relay for an H model then i'd be very keen on taking it off your hands.
Cheers All :wink:
sloweracing
TIMING
Sorry i dont have one in the shed but
If you ring this number 01225427906 and ask for tony or mark £21.50 to youre door not sure if that is good our bad but heres a start.
http://www.bartonmotors.co.uk if tis link does not work try links on my web page good luck
