Firing order
- diesel
- My Bike: Zx7r
gubbs
- My Bike: ZZR1100C3
Re: Firing order
diesel wrote:when you sit on the bike is cyl one on the left or right?
HTH
zxr400 h2 (breaking)
zzr1100c3 (broken)
Vespa et4 (almost broken)
My FleaBay
zzr1100c3 (broken)
My FleaBay
- deviant
- My Bike: ZXR400 L3
Re: Firing order
no, it doesn't really...
Re: Firing order
cylinder numbers from left to right 1-2-3-4 firing order from left to right 1-2-4-3
gubbs
Re: Firing order
You'll be operating on a different left to everyone else then ..deviant wrote:no, it doesn't really...
That explains the mortality rate around here.
Is it a Snenton thing?
zzr1100c3 (broken)
My FleaBay
zzr1100c3 (broken)
My FleaBay
Re: Firing order
Is there anything such as a straight answer anymore???
As i understand it, if you are sitting on the bike, cylinder number 1 is on the left. then 2, 3 and 4 as you go right.
- deviant
Re: Firing order
huh?gubbs wrote:You'll be operating on a different left to everyone else then ..deviant wrote:no, it doesn't really...
you - posted a wiring diagram and said "hope this helps"
i said "no it doesn't really"
which is true. nothing in there tells you the cylinders are numbered left to right - it implies it, and common sense would say that, but I wouldn't take either as a guarantee that they are.
and i live nowhere near Sneinton.
Re: Firing order
well it dos show it..i think..the set of objects second in from the left
Re: Firing order
which would explain the firing order 1-2-4-3rene wrote:well it dos show it..i think..the set of objects second in from the left
