ZXR400 wheelie!
ZXR400 wheelie!
So it definately can be done, but this guy has gone a bit further!
[youtube]http://www.youtube.com/watch?v=aegTmY1q ... ed&search=[/youtube]
Northern ANdy
- My Bike: Unique ZXR400
Re: ZXR400 wheelie!
its not power to weight that gets it up, its all about balance, i've seen people do excerlent wheelys on both zxr's and vfr's its jsut pratice!
- ancozxr
- My Bike: ZXR 400 Track, FMX 650
Re: ZXR400 wheelie!
use an 14 frond sprocket from the 15 stock, and u make wheelie's for fun.
I have in mine ZX and is really cool, but u have to change gears sooner in drive.
Racing for the fearless....!!!!
- Gemini
- cloning technology
Re: ZXR400 wheelie!
vfr's r piss easy to wheelie. i had an rvf which uses the same motor, they have so much low down torque, anyone can wheelie them
zxr's r tricky, but then again, if the trick to wheelies is balance over power then i have been doing them wrong
- deviant
- My Bike: ZXR400 L3
Re: ZXR400 wheelie!
well, i can't actually wheelie (more than a couple of inches), but i'd say it's a mix of both.
if you've got a very powerful bike, then you would be wheelying on the throttle, and the power (or more accurately the torque) will be enough to keep the front wheel at almost any height.
if you haven't got the power, you'll need to clutch it from high revs, and try and use that to get to a steep enough angle that the power is enough to stop it coming down - at which point you are probably dangerously close to looping it. you won't be able to hold the front wheel a constant few inches off the ground as you can on a more powerful bike.
Re: ZXR400 wheelie!
if people can wheelie a CBR125 then a zxr will wheelie fine! its all about balance
Re: ZXR400 wheelie!
The problem i found trying to wheelie was getting the bike up there in the first place.
Re: ZXR400 wheelie!
you sure its with wheelieing?
...some one had to say it
Re: ZXR400 wheelie!
I was expecting someone to say that funnily enough! Yes i am talking about my bike
- deviant
Re: ZXR400 wheelie!
only just actually looked at the videos.
bit of a nob really.
