Gemini wrote:isn't 2500rpm a little high for tickover? i thought most ticked over between 1000 - 1500rpm?
Depends what you like really, i set my tickover to about 2500/3000 when i plan to go for a country road blast and around 1k for commuting through town.
He shouldn't be failing the bike on jumpy revs as thats not a part of the MOT plus it's quite normal for ZXR's to be a little jumpy when the idle is set wrong. If you want to fix it just give the idle speed adjuster a small turn, rev the bike if it doesnt settle properly turn down a little more and so on. It'll still do it once the engines hot again though.
I hate it when MOT testers fail your bike on "Notchy" head bearings, It's quite obvious when head bearings are actually notchy or have play in em, a guy who does MOT's in my area failed my 400 on head bearings after i'd put brand new ones in claiming they were notchy. I did nothing to em took the bike for a retest and he passed it, i told him he could f*** off and issued a complaint with the ministry.
