STRIPPED MY H2 BIKE DOWN OVER WINTER TO GET THE FRAME N EVERYTHING POWDERCOATED N PLASTICS ALL RESPRAYED.
PUT IT ALL BACK TOGETHER N NOW ITS NOT FIRING ON CYLINDERS 1 N 4.
THEY BOTH ON THE SAME COIL, SO TRIED FITTING BOTH COILS FROM MY L MODEL BIKE (SAME PART NUMBER) N STILL NO SPARK.
THE BIKE FIRES NO BOTHER AT ALL BUT IS ONLY RUNNING ON THE MIDDLE TWO CYLINDERS.
ALSO CHECKEDTHE PICKUP SENSOR WHICH IS FINE.
WAS WONDERING IF IT COULD BE THE PICKUP COIL AND HOW HARD THEY ARE TO CHANGE.
ALSO THE BRAKE LIGHT ISN'T WORKING DONT' KNOW IF THIS IS RELATED OR NOT. CHECKED ALL THE CONNECTION NEW BULBS, THE LIGHTS WORK BUT NO BRAKE LIGHT FROM THE FRONT OR REAR BRAKE.
CHEERS
